Great Video
Good video for beginners.
Good Morning. A Question ?. is there any table that relates the Signal Level in dbi with the link capacity.
There isn't such a table, but what you can do is combine the use of the antenna pattern to determine relative signal levels from the peak and then use spec sheets for throughput based on modulation modes and channel size. You have to keep SNR in mind as well because modulation modes are dependent on not just RSL, but also SNR.
It may be easier to use LINKPlanner to run the performance predictions for some coordinates. You can download the tool here.
Thank you for guidance
Video is Okay but no technical part
Thanks for the tips! great video
Thanks for the video !
Thanks for the info… Antenna alignment video
