Any idea when 5.6 FW for F400/425 will be released?
Any word on when 5.6 will be out of beta? There were threads last Sept. about an MCS bug and a stability bug that were supposedly fixed in 5.6RC. Not sure if the MCS bug was fixed in 5.4.2, which is the latest non beta FW.
We are releasing 5.6 on Monday Feb 5.
5.6 Firmware is available now!
Thanks.
Hi Fedor,
I have an issue with the firmware 4.7.0.1 with our F300 and it is not downgradable to 4.6.2 anymore. The thing is it suddenly upgraded to 4.7.0.1 fw.
The last fw version it accepts is 4.6.4. Can you share me this firmware since it is not available on the website?
My email is lornan.mendoza2@gmail.com
I see it in the Archive tab.
https://support.cambiumnetworks.com/files/force300_sm/archive
But before you downgrade, have you tried 4.8.1?
Keep in mind F300 is AC and F400 is AX and they have different FW.
I could not see 4.6.4 on the Archive. Do you have this fw?
No I did not try the 4.8.1… You’re points are noted.
Thanks! But I could not see 4.6.4 on the tab.
