Column calibration_flag is of the wrong data type.
Fixed Base Station Carriers
Column technology is of the wrong data type.
Fixed Link Budget Parameters
Column cell_load,channel_bandwidth,eirp_per_subcarrier,mapl,minimum_signal_strength,required_sinr,required_subcarriers,rx_antenna_gain,rx_noise_figure,rx_sensitivity,spectral_efficiency,subcarrier_spacing,technology,thermal_noise_power_per_subcarrier,total_eirp,total_margins,total_noise_power_per_subcarrier,total_rx_losses,total_subcarriers,total_tx_losses,total_tx_power,tx_antenna_gain is of the wrong data type.
Considering that we are 2 days out from the deadline I think I would recommend to take the cnHeat polygons and convert them to locations using this process. In that way none of this supporting data will be required.
Also, there seems to be a way to do this inside the BDC portal. As I understand it you upload the polygons to the BDC portal. The portal then provides the ability to review the submitted data. You can download the location data from there. If you delete the polygon data and submit the location data that was just downloaded you will not be required to provide the supporting data.
