Class A Emissions Requirements
The following are the major requirements for the CMM5 to meet Class A Emission requirements when fully loaded with access points.
- 240W and 600W AC Power supplies: It is recommended to use a DC line filter as described above.
- CMM5 56V Injectors: In some cases it may be necessary to install Ferrite beads on the input and output CAT5 Ethernet cables. Refer to the installation photos above for the recommended locations of these beads. Recommended device is a large snap on bead with inside dia. 6.3mm, to be used on all 8 pin RJ45 and 6 pin RJ25 within three inches of the CMM5.
