Perform the following steps to bring up the Controller after the Master Injector and any Slave Injectors have been connected and powered on.
Step |
Action |
1 |
Connect the Controller to the Master Injector using the supplied USB cable. |
2 |
Connect the power supply to the Controller power port. |
3 |
A green LED on the front panel indicates the device is powered on. |
4 |
The Controller boots within 30 seconds. |
5 |
Configure the PC Ethernet interface to an unused IP address on the 169.254.1.1/24 subnet. |
6 |
Open a browser window and connect to the Controller using the default IP address: 169.254.1.1 Note: The CMM5 Controller implements a “fallback” IP address of 169.254.1.1 This address is always available to connect to the device regardless of the configuration of the network interface in the GUI. The subnet mask for this address is set to 255.255.255.0. |
7 |
Log in to the Controller GUI using the default username and password.
Note: The Controller username cannot be changed by the operator. |
