CMM5 Injector Firmware Upgrade not Working
I have a scenario labbed up for updating firmware to my CMM5 controllers and injectors. I understand once you update the controller to 1.4 you can then remotely upgrade the master injector from the controller GUI.
I updated the controller just fine and set off the upgrade for the master injector. It was taking so long I left it while I went to lunch and at the point of it being over an hour I said screw it and powered off the controller (I actually thought there would be options under system shutdown, make note that should have a confirmation when you click it). All has come back up with the injector not upgraded.
Any suggestions? I found this post with step by step directions and that was what I did. http://community.cambiumnetworks.com/t5/CMM5/CMM5-Firmware-Upgrade/m-p/95758
