The following paragraphs describe the operating procedures for a CMM5 Injector in standalone mode (Controller not present).
Note: When a Controller is present the Injector operations can be run entirely from the Controller GUI interface. (Refer to the CMM5 Controller Operation section for details.)
Perform the following steps to read the current parameter values from the Injector, and modify them if desired:
Step |
Action |
1 |
Run the TeraTerm terminal emulator and start a serial session to the Injector COM port. |
2 |
Execute the following query command to read the Injector parameters: &0p |
3 |
The Injector responds with the current parameter settings as shown below:
4 |
To enable power on one of the Injector ports, use the following command format: &0p##,0001 Where ## is in the range 01 through 04, representing ports 1 through 4 respectively
5 |
To disable power on one of the Injector ports, use the following command format: &0p##,0000 Where ## is in the range 01 through 04, representing ports 1 through 4 respectively
6 |
To enable sync on one of the Injector ports, use the following command format: &0p##,0001 Where ## is in the range 05 through 08, representing ports 1 through 4 respectively
7 |
To disable sync on one of the Injector ports, use the following command format: &0p##,0000 Where ## is in the range 05 through 08, representing ports 1 through 4 respectively
