There are four optional DC power supplies available.
Cambium Networks Part Number |
Image |
CMM5 240 watt power supply Cambium Networks part number: N000000L054B |
CMM5 600 watt power supply. Cambium Networks part number: N000000L101A |
DIN-rail mounted power supplies that meet full UL approvals:
IMPORTANT!
The power supply or supplies for the CMM5 must be separately ordered. Alternatively, if a +/-48 VDC source is available the CMM5 can be powered directly from that DC source.
You can use Cambium power supplies or an existing +/-48 VDC supply.
Equipment Configuration |
Power Supplies Required |
Notes |
One to Four PMP 450i APs |
240 watt (48-55V) |
With accessories |
Two 5GHz PMP 450m |
240 watt (48-55V) |
With accessories |
Four 5GHz PMP 450m |
480 or 600 watt (48-55V) |
With accessories |
Two 5GHz PMP 450m and two PMP 450i |
With accessories |
Power Line Filter
In order to meet regulatory requirements in certain deployment scenarios, a power line filter module is recommended to be installed on the DC side of the power supply. This module may be ordered from Cambium Networks (part number N000000L056A).
Ferrite Beads
Ferrite beads are recommended to be attached to RJ-45 Ethernet cables to suppress noise and EMI.
What's in Each Box
The following paragraphs describe the contents (product and accessories) for each ordered component of the CMM5.
Injector (56 Volt) Part Number: C000000L556B
Quantity |
Description |
1 |
Injector (56 Volt) |
2 |
Rack Mount Ears (short) |
1 |
Rack Mount Ear (long) |
1 |
6 Foot (1.8 Meter) USB Cable |
1 |
8/32 SS Screw & Nut |
1 |
Connector Bar |
8 |
6/32 SS Countersunk Screws |
2 |
Phoenix Input Connector |
8 |
Ferrite beads for RJ-45 Connectors |
1 |
Ferrite bead for Controller cable |
Injector (29 Volt) Part Number: C000000L529A
Quantity |
Description |
1 |
Injector (29 Volt) |
2 |
1 |
1 |
1 |
1 |
Connector Bar |
8 |
2 |
Providing Sync to CMM5 via cnPulse Module
The cnPulse module provides sync to the CMM5. CMM5 provides power to the cnPulse module. You only need one cnPulse for the entire chain. Cable pinouts are available in the cnPulse knowledge base.
You can procure your own cable or purchase this cable from Cambium Networks.
This cable is an RJ-45 8-pin to RJ-21 6-pin.
N000000L125A |
CMM5 to cnPulse Shielded Cable (20 meter) |
Providing Sync to CMM5 via uGPS Module
The uGPS module provides sync to the CMM5. CMM5 provides power to the uGPS module. You only need one uGPS for the entire chain. Cable straight-Through RJ-12 (6-pins) from SYNC-OUT (uGPS) to the uGPS port on the first Injector of the Daisy-Chain.
N000000L103A |
CMM5 to uGPS Shielded Cable (20 meter) |
