The CMM5 (Cluster Management Module) is the latest generation of solutions for the distribution of TDD Sync signals and “Power-over-Ethernet (PoE)” in the field. The CMM5 is a modular design with individual 4-port power injectors and an optional controller used for remote management.
Key features of the CMM5 include:
- Support for Gigabit Ethernet (1000BaseT)
- Modular and scalable from 4 ports to 32 ports
- Direct +/- 48VDC input (optional AC/DC power supplies are available from Cambium Networks)
- High-power output support for 5 GHz PMP 450m (cnMedusa™)
- Uses Cambium Networks cnPulse or uGPS for a synchronization source
- Dual resilent power inputs
- Rack mountable
- Secure remote management when used with the optional CMM5 Controller Module
- Future support for integration into (cnMedusa™) for cloud or NOC-based management
Cluster Management: Scenario 1
The following is a CMM5 Cluster Management scenario using four PMP 450i Access Points.
Scenario |
Equipment Needed |
Features |
Four PMP 450i Access Points |
56 Volt Injector |
· Gigabit Ethernet · Local Management Interface · +/- 48VDC Input · Broad Device Support · Rack Mountable |
· 48 VDC Available · No management or resiliance required |
cnPulse or uGPS |
Cluster Management: Scenario 2
The following is a CMM5 Cluster Management scenario using four PMP 450i Access Points and four PMP 450 Access Points.
Scenario |
Equipment Needed |
Features |
Four PMP 450i Access Points Four PMP 450 Access Points |
· 56 Volt Injector · 29 Volt Injector · 1 CMM5 Controller · One cnPulse or uGPS |
· Gigabit Ethernet support · Local Management Interface · +/- 48VDC Input · Broad Device Support · Rack Mountable |
AC only environments |
Two AC-to-48VDC Power Supplies |
· Resilent power sources |
Management required. Resilence required. |
· Secure, Remote Management (https) · Scalable to 32 devices |
The major features of the CMM5 Controller Module are:
- Auto-detect/control up to 8 Power Injectors
- Monitor SYNC/Power/GPS status
- Manage (up/down ports)
- Web (HTTPS) and SNMPv2/v3 management
- 1U/ half-width rack-mount
CMM5 Injector Module
The CMM5 Injector Module has the following features:
- Stand-alone mode or used with controller for mgmt.
- +/- 48VDC input with green/amber LED’s for status
- Injects SYNC pulse from cnPulse or uGPS
- 2U / half-width rack-mount
Note that there are two different versions of the injector module (56V and 29V). You must select the correct injector for the types of radios that you will be powering. In both cases the injectors use the same 48-56V input power supplies or can be powered with +/- 48VDC. The output power is different and the type of SYNC signal used is different between the two types of injectors.
The 29V injector uses a physical layer sync signal that interrupts one of the pins every second to pass the 1PPS information to the radio.
The 56V injector uses a different physical layer sync signal that induces the 1PPS signal onto the drop cable. This new physical layer sync signal is compatible with 1000BaseT.
Systems can have 29V and 56V injectors deployed alongside each other.
CMM5 Injector Compatibility Matrix
Product |
Power/Injector Model |
Sync |
PMP/PTP 450i |
Yes/56V |
Yes |
PMP 450m |
Yes/56V |
Yes |
PTP 450b |
Yes/29V |
Yes |
ePMP 2000 |
Yes/56V |
Yes |
ePMP 3000 |
Yes/56V |
Yes |
PTP 670 |
Yes/56V Rev. B |
Yes |
PTP 700 |
Yes/56V Rev. B |
Yes |
PMP 450/PTP 450 |
Yes/29V |
Yes |
PMP 100/PTP 100 |
Yes/29V |
Yes |
PTP 550 |
Yes/56v |
Yes |
* Note: You can only power a 5GHz 450m from the CMM5. The 3GHz 450m needs a separate DC power supply, but can still accept sync from a 56V CMM5 power injector.
CMM5 56V Injector Specifications
The following table provides specifications for the CMM5 Power & Sync Injector (56 Volts).
CMM5 Power and Sync Injector 56 Volts |
Model Number |
C000000L556B |
Data Interface |
4 each RJ45 Gigabit Powered output ports “To Radios” 4 each RJ45 Gigabit Data input ports “To Switch Array” 1 each GPS timing port (RJ-12) 1 each CMM5 USB Serial port for local administration 1 each RJ12 Daisy Chain port “IN” 1 each RJ12 Daisy Chain port “OUT” |
Surge Suppresion |
Lightning Suppression for each “To Radios” RJ45 Port |
Power |
Input Voltage: + or - 48 VDC Input Power Consumption: up to 400 watts Output Voltage: 56 VDC power over Ethernet Output Current: 0 - 1.8A per channel Output Power: 0 - 90 Watts per channel |
Cabinet Temperature |
-40° C to +55°C (-40° F to +131° F), 90% humidity, condensing |
Physical |
Max Distance from Managed Radios: 328 cable feet (100m) Max Distance to GPS Antenna: 100 cable feet (30.5m) |
Dimensions |
8.85” W x 15.75” D x 1.65” H (225mm x 400mm x 42mm) |
Unit Weight |
6.6 pounds (3kg) |
Power Interface Terminals |
2 Power input ports for 48 VDC Power (Power supplies sold separately) |
CMM5 29V Injector Specifications
The following table provides specifications for the CMM5 Power & Sync Injector (29 Volts).
CMM5 Power and Sync Injector 29 Volts |
Model Number |
C000000L529A |
Data Interface |
Surge Suppresion |
Power |
Input Voltage: + or - 48 VDC Input Power Consumption: 240 watts Output Voltage: +29 VDC power over Ethernet Output Current: 0 - 1.0A per channel Output Power: 0 - 30 Watts per channel |
Physical |
Dimensions |
8.85” W x 13.25” D x 1.75” H (225mm x 337mm x 45mm) |
Unit Weight |
3.6 pounds (1.6 kg) |
