Cn-Pilot Eseries
Cambium community
how do you upload a template from cn maestro to e410 series WiFi radios if you want all of them to have similar configuration? All radios are online and onboarded to cn maestro.
How do you create a mesh network using e410 series?
Hello, at a high level you create an AP Group (template) and then on the device configuration page, you apply that AP group to the device.  This link goes into more detail regarding creating the AP Group.  http://community.cambiumnetworks.com/t5/cnMaestro/AP-Groups-and-Overrides-for-Wi-Fi-devices/m-p/71173#M58
For mesh, you will setup a specific mesh SSID and then you will have a configuration for the base (root) AP(s) and the mesh (non-root) AP(s).  This link goes into more detail.  http://community.cambiumnetworks.com/t5/cnPilot-E-Series-Enterprise-APs/How-do-I-setup-a-wireless-mesh-repeater-mode/m-p/52498#M15
and more info:
http://community.cambiumnetworks.com/t5/cnPilot-E-Series-Enterprise-APs/Mesh-feature-FAQs/m-p/56242#U56242
http://community.cambiumnetworks.com/t5/cnPilot-E-Series-Enterprise-APs/How-do-I-set-up-a-multi-hop-mesh/m-p/69230#M90
