Introduction
This document highlights new features and significant updates in cnMaestro On-Premises.
Important
cnMaestro 3.1.0 On-Premises is distributed as an OVA file, which can be installed as a new Virtual Machine or used to update an existing installation running cnMaestro 3.0.0/3.0.2/3.0.3/3.0.4.
Important: Web Browser
Restart your browser (or clear the browser cache with a hard reload) if you are having UI problems with the 3.1.0 version.
Important: Two Interface Installations
Please review the section below on the enforcement changes for Management traffic through eth0 and Device traffic through eth1.
Wireless Client Application Visibility
A dedicated page provides insight into the applications accessed by a Wi-Fi Client. This is only supported for Enterprise Wi-Fi 6 Access Points. The feature must be enabled in the AP Group, so the Access Points collect the application data and forward to cnMaestro.
Applications View
The Application page provides aggregate and time-series application details.
Wireless Client Dashboard and Performance
Wireless Client Dashboard and Performance pages improve insight into Client activity. This feature is accessed by clicking any Client (Clients > Wireless Clients) at the System, Network, Site, or Wi-Fi AP levels.
Wireless Clients Table
The Wireless Clients Table is presented below.
Wireless Client Dashboard and Performance Views
The Client Dashboard provides application and runtime details on the Clients. The Performance page (not shown) displays key performance parameters over time.
CBRS Co-Existence for CommScope and Federated Wireless
Support is added for CBRS Co-Existence using CommScope or Federated Wireless SAS. This support is already available for Google SAS users.
For CommScope and Federated Wireless, a “Merge User ID” option is displayed when importing a new sector. The default behavior (when set to “yes”) results in the tool sending CBRS registration requests with the SAS User ID prepended to the Sector ID and Spectrum Reuse ID. This allows the SAS to distinguish between operators (if both operators pick the same Reuse ID). In most cases, operators will want the default behavior.
See the Cambium 20.3 PMP Training Course on the Cambium Networks Learning site for more information. It details cases where an operator might want to set this to “no”.
Federated Wireless Enhancements
Federated Wireless operators will see the following additions to the Spectrum Inquiry Response pop-up GUI.
A second view of the bar graph showing channel sorting by ranking.
A timer near the bottom of the pop-up GUI which counts down to the next CPAS cycle and guides operators to wait until the timer expires to obtain a newly sorted spectrum inquiry response, before making the final channel selections for grant requests.
See the CBRS Consolidated Procedures Guide for more details.
Other CBRS Enhancements
The addition and countdown timer shown above is available for Google and Federated Wireless operators.
3.1.0 also adds support for newer CBRS alarms and events introduced in PMP version R21.0. The ability for an operator to manually clear these CBRS alarms by alarm type has also been added, as shown in the screenshot below.
Wi-Fi AP Configuration Updates and Bulk Overrides
The Wi-Fi AP Configuration flow has been simplified, and Bulk Overrides are added to efficiently update values across many APs.
Primary Configuration Page
The simplified Device Configuration page is presented below. It is now used to filter devices.
AP Group/Template Selection and Bulk Overrides Page
A subsequent update page supports Bulk Overrides applied to selected devices.
Wireless Clients Report
Existing Wireless Clients Report is enhanced to provide an aggregate view of Client activity within a period. Report generation can be scheduled and downloaded in CSV format from the Administration > Jobs > Reports page.
Note the previous Client Report was a Session Report, which detailed statistics for each Client connection. This has been moved to the Client Dashboard as Roaming History.
Guest Access Login Events Report
A new report type is added for Guest Access Login Events. Report generation can be scheduled and downloaded in CSV format from the Administration > Jobs > Reports page.
Enhanced Packet Capture for Enterprise Wi-Fi APs
The existing Packet Capture tool is enhanced to create a packet capture file (with a ‘.pcap’ extension) that can be downloaded. It allows packet capture on a single interface or simultaneously on multiple interfaces. This feature is supported for Enterprise Wi-Fi APs running software version 6.4 or higher.
SDR Moved to Essentials
The Software Defined Radios (SDR) support for XV3-8 Wi-Fi APs is now an Essentials feature.
Mesh Peers Moved to Essentials
The Mesh Peers detailed view is moved to Essentials.
cnArcher Installation Summary
The cnArcher Installation Summary is available at Network Services > cnArcher Installation Summary. It is only supported by PMP SMs, and the cnArcher mobile application version must be 1.6.37 or higher.
cnArcher is used to install PMP Subscriber Modules (SMs), ePMP SMs, and cnRanger SMs. The Installation Summary provides an overview of the data collected by cnArcher during the installation process.
A list of PMP installations is presented below.
Details are captured and displayed for each install, including pictures taken at the site.
Map Enhancements
The MAP view is moved to the side tabs to provide better access.
Traffic Separation Enforced for Dual Interfaces
cnMaestro supports configuring two interfaces: eth0 for management/cluster traffic and eth1 for control/device traffic. In previous versions of cnMaestro, the Web UI and Device traffic enforcement was not enabled, because they both connected to the same Web Server. This behavior is updated in 3.1.0, and all Web UI traffic is now required to traverse eth0, and all Device traffic eth1.
cnMaestro 3.1.0 enforces Web UI traffic through eth0 and Device traffic through eth1 in two interface installations.
Note
Overriding the management/control traffic separation is possible by applying a network override. The steps are as follows:
Override the Management (eth0) Interface to Accept Control Traffic
- Manually edit /srv/files/etc/cnmaestro-network.overrides to include the following:
iptables -t nat -D PREROUTING -i eth0 -p tcp --dport 443 -j REDIRECT --to-ports 1443
iptables -A INPUT -i eth0 -p tcp -m tcp --dport 443 -j ACCEPT - Restart the system (or type “sudo /srv/bin/cnmaestro-network”)
Override the Control (eth1) Interface to Accept Management Traffic
iptables -t nat -D PREROUTING -i eth1 -p tcp --dport 443 -j REDIRECT --to-ports 1444
iptables -A INPUT -i eth1 -p tcp -m tcp --dport 443 -j ACCEPT - Restart the system (or type “sudo /srv/bin/cnmaestro-network”)
High Availability Deployment Considerations
In a High Availability deployment, if the overrides file is edited on the Primary instance, it is automatically replicated to the Secondary. However the Secondary will still need to be manually restarted in order for the update to take effect.
Citrix Hypervisor Installation
cnMaestro can be installed on Citrix Hypervisor (formerly known as XenServer). For detailed installation steps, refer to Citrix Hypervisor Installation Appendix in the cnMaestro On-Premises User Guide.
API Updates
The Swagger documentation for the updated RESTful API is found at: cnMaestro - RESTful API.
Changes to Existing APIs
Path | Details |
GET /api/v2/networks | Type field is added for 60 GHz cnWave Networks. |
New APIs
Path | Details |
GET /api/v2/cnwave60/networks/{network_id}/devices/overrides | Multiple device configuration. |
PUT /api/v2/cnwave60/networks/{network_id}/devices/overrides | Commit multiple device configuration. |
GET /api/v2/cnwave60/networks/{network_id}/links | Network level links topology. |
PUT | |
/api/v2/cnwave60/networks/{network_id}/links/{link_name}/{ignition | status} |
POST /devices/{mac}/pull_config | Initiate device pull configuration request. |
GET /devices/{mac}/pull_config | Returns result of device pull configuration request. |
Features Removed
Feature Name | Details |
L2GRE/EoGRE Tunnel Concentrator | As communicated during the 3.0.0 On-Premises release, this feature is removed in 3.1.0. Please refer to the community post for more details - Deprecating L2GRE Concentrator from cnMaestro on premises |
Supported Cambium Products
cnMaestro supports the following Cambium Networks products. The software versions are the minimum required to use cnMaestro (not the recommended versions).
Family | Model | Version |
60 GHz cnWave | V1000 | 1.0 |
V3000 | 1.0 | |
V5000 | 1.0 | |
cnMatrix | EX2K/EX1K | 2.0.4-r1 |
cnPilot Home | cnPilot R200, R200P | 4.4.2-R2 |
cnPilot R201, R201P | 4.4.2-R2 | |
cnPilot R190V, R190W | 4.4.2-R2 | |
cnPilot R195P | 4.5.2 | |
cnPilot R195W | 4.7 | |
cnRanger | Sierra 800 | 1.0.1.0-r1 |
Tyndall 101 | 1.0.1.0-r1 | |
Tyndall 201 | 2.0.0.0-r1 | |
cnReach | N500 | 5.2.17e |
cnVision | Hub 360r, FLEXr | 4.6 |
Client Micro, Mini, Maxr | 4.6 | |
Enterprise Wi-Fi | cnPilot e400/e500 | 2.5.2-r3 |
cnPilot e410/e430w/e600 | 3.5.2-R4 | |
cnPilot e501S/e502S | 3.2.1-r6 | |
cnPilot e700 | 3.8 | |
cnPilot e425/e505 | 4.0-r17 | |
cnPilot e510 | 3.11.4-r9 | |
XV3-8 | 6.0 | |
XV2-2 | 6.1 | |
XV2-2T0 | 6.3.5 | |
XE3-4 | 6.4 | |
ePMP 1000 Hotspot | ePMP 1000 Hotspot | 2.5.2-r3 |
ePMP | ePMP 1000, Force 180/200 | 2.6.2 |
ePMP 2000 | 3.0.1 | |
ePMP Elevate XM/XW | 3.2 | |
ePMP Force 190 | 3.5 | |
ePMP Force 300 | 4.1 | |
ePMP PTP 550 | 4.1.1 | |
ePMP Force 130 5 GHz | 4.3.2 | |
ePMP 3000L | 4.3.2 | |
ePMP Elevate SXGLITE5, LHG5 | 4.3.2.1 | |
ePMP Force 130 2.4 GHz | 4.4 | |
ePMP Force 300-19, 19R, 13 | 4.4 | |
ePMP 3000 | 4.4.1 | |
ePMP PTP 550 E | 4.4.2 | |
ePMP MP 3000 | 4.5 | |
ePMP Force 300-13L | 4.5.2 | |
ePMP Force 300-13LC, 22L, 25L | 4.6 | |
ePMP Force 200L | 4.7.0 | |
ePMP 4000, Force 400 GPS, 400 CSM, 425 | 5.1.0 | |
PMP | PMP 450i, PMP 450, PMP 450m, PMP 430 SM | 15.0.1 |
PTP 450, and PTP 450i | 15.0.1 | |
MicroPoP Omni/Sector | 16.2.1 | |
PTP | PTP 650 | 01-47 |
PTP 670 (650 Emulation) | 01-47 | |
PTP 670, PTP 700 | 02-67 |
Supported Browsers
cnMaestro supports the following browsers:
Platform | Browser | Version |
Linux | Firefox | 45 and above |
Chrome | 49 and above | |
MacOS | Safari | 9 and above |
MS Windows | Internet Explorer | Deprecated |
Microsoft Edge | 44.17763.1.0 | |
Firefox | 45 and above | |
Significant Fixes
The following issues have been fixed:
Id | Details |
CNSSNG-20441 | DMZ external proxy is not working when cnMaestro has no internet. |
CNSSNG-20556 | Cannot sort wireless clients by hostname. |
CNSSNG-21169 | If an MSP account user is deleted, then the devices claimed by that user are not reconnecting to cnMaestro. |
CNSSNG-21590 | AP not syncing: Configuration failed: system_name: Only alphabets, digits, hyphens and underscores are allowed. |
CNSSNG-22079 | RF Quality does not update properly for ePMP 11 AX SM devices. |
CNSSNG-22190 | Alarm count is seen, but no record found in the alarms when clicking on the alarm. |
CNSSNG-22343 | Alarm for link down still exists even if link is removed. |
CNSSNG-22443 | URL is stripped in the latest cnMaestro version 3.0.4-r59. |
CNSSNG-22473 | Announcement sync fails on on-premises connectivity. |
CNSSNG-22506 | SNMPv3 Username, SNMPv3 Password are mandatory fields under Enterprise AP Groups>Configuration>Management. |
CNSSNG-22911 | Clients Now column in AP Groups table is not updating properly. |
CNSSNG-22931 | Does not showing performance on SFP port of TX2012R-P |
CNSSNG-23062 | Offline APs shown as online. |
Known Issues
The following issues exist:
Id | Issue | Details |
CNREACH-139 | Radio Software Update is not happening for EP-based devices. | |
CNSSNG-4083 | DHCP errors after cnMaestro reboot | When cnMaestro On-Premises is rebooted, after Data Import, sometimes DHCP and Disk Errors are encountered. Workaround: Explicitly run the dhclient command from the Command Line (accessed through the CLI) after reboot to assign the IP address. |
CNSSNG-5365 | RADIUS Proxy drops packets after retrying exhausted | After RADIUS Proxy Retries are exhausted in cnMaestro On-Premises, all subsequent RADIUS packets are dropped. Workaround: Reboot cnMaestro server. |
CNSSNG-9631 | High Availability: Network cable unplug: Device count is taken from Primary and jobs/users list is taken from Secondary. | |
CNSSNG-9632 | High Availability: Network cable unplug: Devices onboarded during network disconnect need to be reapproved by user. | |
CNSSNG-10145 | Certificate exports are not part of Data Backup and Restore | Certificates must be exported manually. |
CNSSNG-10187 | During Migration, moving, or deleting a device from the Managed Account will mark all events and alarms as undefined once Migration has completed | |
CNSSNG-11299 | AP Regulatory Channel list support check needed for checking valid channels. | |
CNSSNG-11389 | Microsoft Edge Browser does not support in system OVA file upgrade. | Workaround : Use the Google Chrome browser |
CNSSNG-11987 | Failed - Bad Certificate’ errors while downloading the generated report after a period of report generation. | |
CNSSNG-12812 | cnPilot R-series dual radio devices (r-201P, r-195W) AP Group country code/SSID configured from overrides getting applied only to 2.4 GHz radio. | |
CNSSNG-12888 | Connected Clients count in the WLAN page is not properly shown when SSID is overridden for the WLAN at Device level. | |
CNSSNG-13054 | Mismatch in Clients count for cnPilot E-series device at WLAN and AP Group configuration level. | |
CNSSNG-14030 | CBRS race condition: SM “stuck” in cnMaestro during reparenting if import and start occurs as SMs arrive in onboarding queue | Workaround : To avoid this issue, follow the suggested SM reparenting procedures listed in the latest version of Cambium CBRS standalone procedures document. |
CNSSNG-14518 | Device Type selection needs to be provided at Site and AP Group for Report generation. | |
CNSSNG-15432 | Deleting a device in Base Infrastructure and claiming it immediately to another Managed Account returns Device Registration Failed message. | |
CNSSNG-15595 | cnMatrix Hostname fall backs to old Hostname if the template is pushed for the first time (if a Switch Group already exists) | |
CNSSNG-15656 | Duplicate entries observed in 802.11ax Clients Report. | |
CNSSNG-15838 | Issues related to Monetization Subscription Events. | |
CNSSNG-16019 | Subscriptions are not listed in the correct order. | |
CNSSNG-16197 | CBSDID search will not work when device was synced from tool without obtaining grant first. | Workaround : Perform CBSDID search from domain proxy view on Cloud to obtain mac address, then perform MAC address search on tool to find the device. |
CNSSNG-17011 | After the migration completed for PPPoE with server update, devices still show in sync. | Workaround : User must manually apply the AP Group again on devices with minor changes to the AP Group. |
CNSSNG-18710 | Tier issues related to 450i, 450i AP, and 450i SM. | |
CNSSNG-18913 | On resizing, the graph/widgets are not properly rendering. | |
CNSSNG-18923 | After migration Reports Job page is empty due to cached data. | Workaround : Clear Cache and Cookies after migration. |
CNSSNG-18927 | Configuration push from Onboarding page is getting device timeout error in ePMP 1000 Hotspot device. | |
CNSSNG-18936 | Graphs plotting is getting empty if the page is zoomed out/in. | |
CNSSNG-19264 | Unmanaged expired device approve button is not disabled. | |
CNSSNG-19273 | Expired Wi-Fi devices are not handled for AP Group dashboards and tree level. | |
CNSSNG-19274 | Expired devices count should not be added to connection health graph. | |
CNSSNG-19275 | Issues related to Offline alarm of expired devices. | |
CNSSNG-19511 | support for scheduled config jobs feature is missing at Switch groups > Switches > Actions > Configuration tab | |
CNSSNG-20508 | Last Super Administrator deletion should be shown proper error message. | |
CNSSNG-20605 | User-Defined Overrides (Advanced) should be handled from Switch Groups > Switches > Actions > Configuration tab. | |
CNSSNG-20745 | AP Count is -1 in Anchor when deregistering the device from Anchor. | |
CNSSNG-20820 | After server upgrade, device throws error [Invalid CBSD ID and Grant ID], even the Domain Proxy shows the device is registered. | |
CNSSNG-21068 | Not able to deregister or delete the SM when PMAC mismatched (SM reported different PMAC). | Workaround: Reinitialize the SM from inside the sector of the AP, not by directly searching for the SM in the tool; then deregister and delete the device. |
CNSSNG-21264 | Auto refresh is not working when Site/Tower/Device details are updated in network level map. | |
CNSSNG-21268 | cnMatrix devices are not reflecting in maps. | |
CNSSNG-21271 | Map: SM status is missing in AP details. | |
CNSSNG-21345 | RF Statistics related information should not be available in reports for XV type device. | |
CNSSNG-21396 | Issues related to cnMatrix onboarding overrides. | |
CNSSNG-21425 | Left side menu is not properly shown in Firefox browser. | |
CNSSNG-21703 | SM icon is missing in Network-level Maps. | |
CNSSNG-22089 | New Changes in Clients report in 3.1.0. | |
CNSSNG-22116 | On Demand Packet Capture: Supported Channel list for few country codes differs between CnMaestro and AP. | |
CNSSNG-22518 | Start now/ later buttons should be disabled if wireless LANs are not selected. | |
CNSSNG-23100 | The device overrides are getting updated with null values on every device reconnect. | |
CNSSNG-23284 | UI does not allow to save configuration for eth4 interfaces. | |
CNSSNG-23298 | Cloud Sync with cnMaestro as Proxy server will not work. | Workaround : Use the external server proxy |
CNSSNG-23322 | Cloud sync: cambium id is not getting updated if the cloud sync fails on the first attempt after OVA upgrade | Workaround : Find the pid of the CnsCloudSyncServer using "sudo ps -ef |
Where to Get Help
There are several places to get help with cnMaestro.
Cambium Community : The cnMaestro Forum provides the best place to ask questions and get up-to-date information.
On-Premises Quick Start Guide : This guide walks you through the initial management process and allows you to get onboard quickly. It is embedded into the cnMaestro image and can be accessed on the Home Page of the UI. It can also be downloaded in PDF format from the Cambium Support website.
Cambium Support : The Cambium Support team is available 24x7 to answer questions and resolve issues.
