E600 detail specification
Can somebody share with me the detail specification of cnPilot E600. I cannot find the detail on the datasheet (DRAM, flash size, processor, detail data rate, supported protocol etc).
we'll update the datasheet with this, in the meantime here are some of the details you were looking for:
Processor: Quad-core ARM CPU 700+Mhz.
DRAM : 256MB
Supported protocols: radio: 802.11a/b/g/n/ac/ac-wave2. sw: 802.11e/d/r/u/w
RF: 4x4 802.11ac-wave2 with MU-MIMO & transmit beamforming on 5GHz. 2x2 802.11n on 2.4GHz.
Channel Width: 20/40/80 (160MHz enabled in an upcoming software update)
Can some one show me how to onboard cn pilot e600
E600 onboarding methods are similar to E400 & E500. Please find the link below for different types of on-boarding methods supported by cnPilot devices:
http://community.cambiumnetworks.com/t5/cnMaestro/On-boarding-Prerequisites-and-Procedures-Part-1-of-4/m-p/51406#U51406
Thank You.
Does e400 and e410 have all these features too?
the e400 is a previous generation, slower CPU with half the RAM. It also does not support beamforming.
the e410 does support beamforming etc, but is a 2x2 MU-MIMO radio (unlike e600 which does 4x4 on 5GHz). The e410 also has single ethernet port, no USB, no BLE.
A product comparison is here:
cnPilot Enterprise Portfolio
Sorry for not asking clearly. I was specifically asking whether the e400/410 support these protocols as well - 802.11e/d/r/u/w
Yes the e400 and e410 also support those protocols
Good reference chart!
