Firmware 4.7 para forcé 300
Buenas tardes a todos
Quién tiene la versión 4.7 de cambium para los force 300 para el tema multipuntos le agradezco su colaboración mi WhatsApp es +57 3158314363 o correo lidertecnicosucre@grupogexo.com
https://support.cambiumnetworks.com/file/40a49815a76fef22573f70dc2b2c4168a401c2d0
Note that you will need to join the ePMP Beta program to download that file:
https://support.cambiumnetworks.com/files/force300_sm/beta
More details here:
le.coloque ese pero solo me aparece un cliente
Is that the same problem as described here?
https://community.cambiumnetworks.com/t/epmp-software-release-4-7-rc7-beta-is-now-available/82861/61
If so, I think it’s under investigation.
Yes Force 300C is affected with the same bug.
Yeap. This is the known issue. It will be fixed in stable release.
buenas tardes tengo un force 300-csm para conecterizar pero lo actualice en beta y no deja hacer multipunto solo un cliente en cambio el force 300-19r si deja 12 supcritores
es de cir para la force 300-csm no ahi version para que funcione en modo pmp
gracias por su atencion
Google Translate:
good afternoon I have a force 300-csm to connect but I updated it in beta and it does not allow multipoint only one client instead the force 300-19r if it leaves 12 subscribers
it is from cir for the force 300-csm there is no version to work in pmp mode
thanks for your attention
This is a known issue and the fix has not been released yet:
