Force 180 served as standard WIFI AP. It is possible?
Hi guys,
I have 2 extra Force 180 units and I'm wondering either it can be used as a standard WIFI AP for clients?
I tried to enable it but still can't detect it via mobile phone/laptop (support both 2.4 & ghz).
Radio Mode : Access Point
Drive Mode : Standard WiFi
WLAN : Enabled
Country : Other
Max Registrations Allowed : 120
Operating Frequency : 5555 MHz
Operating Channel Bandwidth : 20 MHz
Transmitter Output Power :10 dBm
Antenna Gain : 16 dBi
Downlink CTS : Enabled
Uplink RTS/CTS : Enabled
RTS Threshold : 2346
Mike
Configuration looks good.
Except Operating Frequency : 5555 MHz. It is not standard Wi-Fi channel.
Please try to use 5550 or 5560 MHz.
Thank you.
If your phone supports 802.11n in 5ghz ( most dont) i would try a laptop that does.
The fix is works perfectly.
Beside 5550 and 5560, any other standard wave supported?
I have few units spare and wondering if I can do 360 degree coverage (3 units) without interference to each other?
You can find list of standard channels for 5 GHz for exemple in Wikipedia:
https://en.wikipedia.org/wiki/List_of_WLAN_channels
Thank you.
Thank you guys for the really helpful to setup my Network topology.
