What is everyone using for wiring the 3.6 450m power cable and where are you ordering it?
We've been using THIS cable.
What are you using for a crimper?
Here is another option for you. THIS
Eric: Have you experimented at all? Or did you use that from the get go and just roll with it?
Also for the crimper, look for a DB9 crimp tool... and a DB9 pin insertion/removal tool. Both can be had for cheap.
I haven't experimented at all. I'm just a desk jockey... I got that information from our project manager that actually hangs these things. What do you mean by experimented?
Eric,
I see! Was just mainly curious to see if you or your guys have tried other cable to see what you like best. We used some 4 conductor 16-AWG from Monoprice as I linked above. It's plenum as well!
-Anthony
@Anthony_SBB wrote:Eric,
-Anthony
Our tech likes the cable and the crimpers we have... everything seems to work/fit properly... no need to really try anything else.
