Summary: This article describes how to configure client Web Proxy details for your cnPilot, Xirrus and XV/XE series APs.
Note: This functionality is only available on CaOS 6.4 and upwards for the cnPilot and XV/XE series APs.
cnPilot & XV/XE Series AP’s
SSH in to the AP using a web terminal application such as PuTTy
Enter the following commands, replacing items marked with < >, with values suited to your environment
management proxy https
management proxy https host <ip address>
management proxy https port <port>Optionally, you can use Username & Password if it is required by your Web Proxy
management proxy https username <username>
management proxy https password <password>If you wish to remove the Web Proxy configuration, you can use the
nocommandno management proxy httpsExample configuration
Once you have completed the configuration, save the configuration to flash memory using the save command.
save
Xirrus APs (AOS only)
SSH in to the AP using a web terminal application such as PuTTy or use the console based Xircon
Once logged in, use the following commands, replacing items with < > with values that suit your environment
configure
proxy-mgmt
https enable
https host <ip address> port <port> username <username> password <password>
saveAlternatively, you can use HTTP
configure
proxy-mgmt
http enable
http host <ip address> port <port> username <username> password <password>
saveExample
