How to convert an existing PTP800/810 antenna for PTP820 direct mount?
For all PTP800/810 direct mount antenna, we offer a solution which can convert the antenna to PTP820 direct mount, so customer will be re-use the same antenna, no alignment need.
First, you will need order the PTP820 interface plate depends on which frequency the antenna is:
N060082L004A PTP 820 RFU-C interface plate for 6GHz ( CR4)
N070082L003A PTP 820 RFU-C interface plate for 7GHz ( CR4)
N110082L003A PTP 820 RFU-C interface plate for 11GHz ( CR4)
N130082L003A PTP 820 RFU-C interface plate for 13GHz ( CR4)
N150082L001A PTP 820 RFU-C interface plate for 15GHz ( CR4)
N180082L001A PTP 820 RFU-C interface plate for 18GHz ( CR4)
N230082L001A PTP 820 RFU-C interface plate for 23GHz ( CR4)
Then you will need follow these steps:
Step 1: Remote the PTP800 ODU interface plate
Antenna with PTP800 ODU interface plate
after the interface plate removed
Step 2: install the PTP820 interfece plate follow the Andrew installation procedure (attachement)
Regards
Allen
Hello Allenyu! Does it work for another antenna makers? I see the part is Andrew but I'm using RadioWaves antennas.
Regards
Does this link answer your question?
http://community.cambiumnetworks.com/t5/Licensed-Microwave/Re-Use-Existing-Antennas-for-PTP820/m-p/84401
I hope this helps!
Dave
Hehe! Yes, partially! Thanks! I only see for 11 & 18 GHz on RadioWaves. There's no 23 GHz?
Unfortunately there is no convert for 23 GHz today. It could be done but overall the demand is very low so far.
Regards
Allen
