How to enable the Remote Management access on ePMP/PTP 550 (Access Point/Master)
Summary:
This article demonstrates how to enable the “Remote Management Access” for ePMP/PTP 550 (AP/Master).
Cause:
By default, management access on an AP/Master is only allowed via the Ethernet Interface. We can enable the management access for a wireless interface which will allow us to access the AP/Master from behind the SM/Slave.
Solution:
There are many ways to enable the “Remote Management Access” including:
  1. Via the device GUI (Simplest way)
  2. Using SSH
Method 1: Via the device GUI
Step 1 : Login to the web GUI of the AP/ Master.
Step 2: Navigate to: Configuration → Network → Advanced tab and set the “Management Access” to “Ethernet And Wireless” and save the change as shown below (Reboot not required):
Method 2: Using SSH.
Step 1: Login to the AP/Master via SSH.
Note: You can use any SSH client. For Windows, Putty can be downloaded from https://www.putty.org/
Step 2: Enter the following commands in CLI as shown below:
config set l2WanRemoteAccess 1
config commit
Note:
A device reboot is not required to make this change
To set the “Management Access” back to Ethernet only use the following command:
config set l2WanRemoteAccess 0
config commit
i am facing same problem can anyone here tell me, how can we solve this
Hi @josh_bez,
what kind or problem do you have?
A post was split to a new topic: How do I strip VLAN tags on ePMP
Same problem..
Same as what? This topic describes how to enable Remote Management. Are you having a problem following the instructions? If so, what is the problem?
