1 Introduction
This document outlines about the different Tools available in cnMaestro for troubleshooting various device related issues and the scenarios.
2 Tools
cnMaestro has many debugging tools. The cnMaestro’s tools are listed below:
- Pictorial view of network hierarchy
- Link mode and speed
- Device status
- Tech support file
- RF link quality
- Throughput
- Latency
- Alarm
- Reboot
- Associated clients
- Client Health (logs and packet capture)
- Network connectivity – ping, DNS lookup and traceroute
- Alarms
- WiFi Analyzer
Tools and its details
Pictorial view of network hierarchy |
User can view the hierarchical representation of end to end network from AP->SM->WiFi Device |
Link mode and speed |
User can get the details about Link Mode(Full or Half Duplex ) and Speed (100 Mbps or 1 Gbps) for AP/SM/WiFi Device Links |
Device status |
User can get the details of device status indicating down or up for AP/SM/WiFi devices based |
Tech support file |
User can download the Tech support file for the AP/SM/WiFi Devices which will be helpful in debugging the device issues |
RF link quality |
User can get the details about the RF Link quality between the AP and SM devices. The quality is depicted as Poor/Good/Excellent based on the MCS values for uplink/downlink |
Throughput |
User can get the details of the Throughput between the AP and SM device for both uplink/Downlink |
Latency |
User can get the Latency details between the AP and SM or SM and WiFi devices |
Alarm |
User can get the Active Critical/Major Alarm Count details for AP/SM/WiFi Devices |
Reboot |
User can reboot the AP/SM/WiFi Device using the Reboot button |
Associated clients |
User can get the details of the Associated Clients for the WiFi Device |
Client Health (logs and packet capture) |
User can get the details of all the Clients connected and their RF and non RF parameters and also they can capture the packets as well as get logs for the WiFi devices |
Network connectivity – ping, DNS lookup and traceroute |
User can know the connectivity is working fine or not using the connectivity tools for AP/SM/WiFi Devices |
Alarms |
User can get the details of the Active Alarms present for the selected AP/SM/WiFi devices |
WiFi Analyzer |
User can get the details of the RF interference from other WiFi Devices and the channels in which they are operating and other details so that they can plan the design of their network. |
3. Scenarios
3.1 Scenario 1 : Traffic flow Issue
cnMaestro tools help to diagnose exact problem in case the traffic is not flowing or Internet connectivity is lost or there are a lot of packet drops observed.
a) |
Which link is up/down |
Select WiFi device you want to troubleshoot and navigate to Monitor >Tools page. The hierarchical pictorial representation lets you know whether the link between: · AP and uplink switch is up/down · AP and SM is up/down · SM and WiFi Device is up/down. |
b) |
Why there are Packet drops |
Select the WiFi device you want to troubleshoot and navigate to Monitor >Tools page. Click on the Latency link between the AP and SM or SM and WiFi Device and cnMaestro lets you know how much is the latency between the devices. If latency is high then the Link between AP/SM/Wifi will not be stable and there will be packet drops. |
c) |
Speed and Duplex |
Select the WiFi device you want to troubleshoot and navigate to Monitor >Tools page. The hierarchical pictorial representation of the devices shows the Uplink speed and duplex from the AP to the Switch/Router and the speed and duplex between the SM and WiFi Device. This will help in identifying any Speed or duplex issues and rectify them. |
d) |
RF Link Quality |
Select the ePMP SM device you want to troubleshoot and navigate to Monitor >Tools page. The hierarchical pictorial representation of the devices shows the RF link quality between AP and SM as shown in the screenshot. |
3.2 Scenario 2 : Network connectivity
Helps user to check the device Network connectivity with the outside or inside networks.
Use the cnMaestro >Tools > Network Connectivity options like Ping/DNS Lookup/Traceroute to accomplish this task. This is available for all device types.
a) |
Ping |
Select the Ping option from the drop down of Test Type field under Monitor > Tools > Network Connectivity menu and enter: · Valid IP Address or Hostname the · Number of packets · Buffer size Click Start Ping option. The results will be displayed in the bottom text area. |
b) DNS Lookup |
Select the DNS Lookup option from the drop down of Test Type field under Monitor > Tools > Network Connectivity menu and enter a valid Hostname. Click the DNS Test button. The results will be displayed in the bottom text area.
c) Traceroute |
Select the Traceroute option from the drop down of Test Type field under Monitor >Tools > Network Connectivity and enter: · Valid IP Address or Hostname · Make proper selection for Fragmentation, Trace Method, Display TTL, Verbose Click the Start Traceroute button. The results will be displayed in the bottom text area. Click on Stop Traceroute button in case you want to terminate the operation. |
3.3 Scenario 3 : RF interference
Helps user to check the RF interference in the WiFi device deployment site.
Monitor >Tools section WiFi analyser helps in identifying the RF interference in the WiFi device deployment site. This option is available for only WiFi devices.
Go to Monitor > Tools > WiFi analyser after selecting a WiFi device in the Tree and select the Band 2.4/5 GHz. Click Start Scan to start scanning.
The results will be displayed as graph and tabular format. The graphs shows RSSI/Noise vs channel number of the particular Band. It also provides toggle button to see Number of APs/ Noise vs channel number. This information will be useful for planning WiFi device deployments.
3.4 Scenario 4 : Device logs and packet capture
Helps user to check my device Logs or do a packet capture without logging into the device.
a) |
Debug Logs |
Navigate to below path to collect logs from device without logging into the device. · Monitor > Tools > Debug for ePMP/PMP products · Monitor > Tools > Client Health for WiFi products Select the Logs option from the drop down and click Start Logs. You can wait until the operation completes or you can click Stop Logs to terminate in between (captures partial logs).
b) Packet Capture |
Monitor > Tools > Client Health page helps to capture the Packets from device without logging into the device. Select the Packet Capture option from the drop down and: · Select Ethernet, Wireless Lan or WLAN option from Interface dropdown · Enter Number (interface number) and Count (number of packets) Click Start Capture. Wait until the operation completes or you can terminate the process after collecting partial log by pressing Stop Capture button.
3.5 Scenario 5 : Unconnected clients
Helps user to know the failed attempts by clients trying to connect to the WiFi device.
Monitor >Tools > Unconnected Clients shows the details of failed connection attempts of clients to WiFi device. By this user get to know what are MAC Addresses of the clients failed to connect and its reason for failure attempt like Wrong Password or blacklisted etc..
3.6 Scenario 6 : Tech support file
Helps user to contact the support team in case user is unable to investigate root cause using cnMaestro provided debugging tools.
Go to Monitor > Tools page and click Tech Support file icon (highlighted in below screenshot) to download logs and config file of the device. This file can be sent to the Cambium Support team for further debugging of the issue. It is supported for all device types.
3.7 Scenario 7 : Client health
Helps user to know the health of various clients connected to the WiFi device.
Monitor > Tools > Client health helps in identifying:
- Client related details like Name, IP/MAC Address, Manufacturer, WLAN
- Data uploaded and downloaded
- Operating frequency band
- Signal strength(RSSI) and Signal to Noise Ratio (SNR)
3.8 Scenario 8 : Alarms
Helps user to know the Active Alarms of the device.
Monitor > Tools > Alarms provides the list of Active alarms currently present for the device.
