https:// removal
I just notice on new Cloud management you have to remove the https to access online SM radios or you get an error..
This site can’t be reached
https://192.168.1.153 refused to connect.
Try:
ERR_CONNECTION_REFUSED
Hi ,
This is expected behavior as we changed the default management protocol to https which is mroe secure instead of http starting 2.2.0 release.
KR.
Just to be clear on this. We should push a config file to all SMs to change access from http to https? It was nice before when it would find it either way.
Thats really annoying. Now I have to reconfigure thousands of radios to get the links to work in Maestro. Awesome job Cambium.
@Kevin Simms
You could make use of the below communtiy link to enable https based on the device model.
http://community.cambiumnetworks.com/t5/cnMaestro/How-to-enable-HTTPS-on-ePMP-PMP-and-cnPilot-devices/m-p/105863
