This article explains how to manage Onboard E2E Controller (Enabling E2E Controller in 60GHz cnWave Device) in cnMaestro
Enable Onboard E2E Controller in 60GHz cnWave Device
Access 60GHz cnWave device GUI using IP address and enter user credentials.
Click on Sign In button to login to 60GHz cnWave device GUI
Navigate to Onboard E2E Controller and click on Enable E2E
cnMaestro Management Configuration in 60GHz cnWave Device
Once Onboard E2E Controller is enabled, Enable Onboard E2E window pops up to configure basic parameters (Site, Network and Controller details)
Scroll down to configure cnMaestro Remote Management configuration. Under cnMaestro section, select Enable Remote Management
Enter cnMaestro URL where cnMaestro server is running (On-premises or Cloud). If “Cambium ID based authentication” option is enabled in cnMaestro then need to enter cambium ID, Onboard key as well
cnMaestro On-Premises
cnMaestro Cloud
Now click on Enable button
Manage Onboard E2E Controller in cnMaestro
Once Onboard E2E Controller is enabled with cnMaestro Remote Management configuration, 60GHz cnWave device Dashboard shows " Waiting for Approval " under cnMaestro Connection Status
Now Login to cnMaestro and navigate to Monitor and Manage>System, new 60 GHz cnWave Onboard E2E Controller network will be displayed. Click on Approve button
60GHz cnWave - Network Onboard window pops up with default Onboard E2E Network Name. Edit Network Name if required (optional) and click on Save button to manage Onboard E2E Controller
Wait for a while till Onboard E2E Network is successfully managed in cnMaestro
After successfully onboarded, the Onboard E2E Network shows the Dashboard of the network
How do I know Onboard E2E Controller is Enabled in 60GHz cnWave Device
In 60GHz cnWave Device Dashboard, E2E Controller shows Running Onboard
How do I know Onboard E2E Controller is managed to which cnMaestro in 60GHz cnWave Device
In 60GHz cnWave Device Dashboard, cnMaestro Connection Status shows Connected with cnMaestro IP
How do I know cnMaestro is managing the Onboard E2E Controller?
Navigate to Monitor and Manage>System>Onboard E2E Network (which is managed)> Dashboard and check E2E Controller details
Unable to manage Onboard E2E Controller in cnMaestro, what should I do?
In 60GHz cnWave Device GUI, navigate to Onboard E2E Controller>cnMaestro tab and click on View DA Logs. Download the DA logs and share with support team
What should I do if I don’t want to manage Onboard E2E Controller in cnMaestro
In 60GHz cnWave Device, navigate to Onboard E2E Controller>cnMaestro tab, select Disable under Remote Management and click on Submit button
