Maximum length of cat5 cable between CMM5 and PMP450i
Hi!
Is there any recommended maximum length of cat5 cable between CMM5 and PMP450i? Both power and data go through this cable.
Yes, the maximum cable length for this is 100m, provided you are using the recommended Power Supply with the CMM5.
As a side note, see the KB article here regarding the maximum cable length between a PMP450i and uGPS/cnPulse in case you end up using the AUX sync method instead of a CMM.
Also, now that the uGPS has been replaced by the cnPulse device, the cable is no longer an RJ12 to RJ12 for connecting the cnPulse to a CMM5.  More information available here and here.
