N000082L022 work with 670?
Hello,
I have been searching the forum and, through a few various posts, I think i have figured out that p/n N000082L022 can be used to power a PTP670 off of a 24vdc input, but i wanted to double check. Per the install guide, the AC+DC POE that comes with the 670 only accepts 37-60vdc input. There is only 24vdc power available at the site so I am hoping using this will eliminate the need for extra 3rd party equipment.
Can anyone confirm this for me please?
Thanks!
EJ,
     Check out the following link with POE requierments for the 650/670. I would look into this as well.
http://community.cambiumnetworks.com/t5/PTP-FAQ/PTP-650-Compatibilty-with-802-3at-standard-PoE/m-p/50740#U50740
Thanks for the info Justin,  i did not realize that the 670 could use standrd 802.3at, but in the mode a alternative, and passive. If needed, im sure we can find a DC fed, mode a injector. thanks!
No worries EJ!
