We are a WISP based in Africa and have recently purchased the PMP 450b for Subscriber Modules (SM) and the PMP 450 for Access Points (AP). We are facing challenges with network configuration, particularly with VLAN settings, as we need to support two scenarios: single VLAN and trunking.
Could anyone provide clear guidance or best practices on how to properly configure these settings? Your support would be greatly appreciated.
Also, if you still have further questions. Please, help open a support ticket with the specific questions for us to help further - https://cambiumnetworks.zendesk.com.
As mentioned by @Cambium_Lena , the radios PMP 450b works by default in a transparent mode. If ever you want to tag a single VLAN on the radio as an access VLAN, meaning you will not need to tag anything at the router connected to this antenna (That is in case you configure for example a public IP address or a PPPoE username and password on the router), here is the step:
