Is it possible to use 2+0 configuration with a PTP820C as per screen shot below and achieve the 2Gbps shown. Or am I missing something, I’ve read elsewhere that the license only allows 1Gbps… Thank you
Hello Brandon,
this is possible, note that the PTP 820C is a dual core radio. Hence, what you have here is the PTP 820C (2+0 into CCDP configuration) with the dual core radios in operation to achieve 1 Gbps in one direction and 2 Gbps in both directions (Transmit and receive) also called aggregate throughput.
Sincerely yours,
Niragira Olympe
