I am setting up a PTP850S for the first time and I need to setup it for in-band management and also do a single cable solution all on VLAN 1 only.
Do I need to tag the Management SP 31 and set it to vlan 1 C-VLAN encapsulations or leave it untagged? Im reading that the managment SP should be tagged?
On a PTP820S the MNG port is a diffrent port so I setup the services on eth 1 untagged dot1q for the 257 MNG and select untagged on the service points for Eth slot 1 port 1 and radio slot 2 port 1 and a P2P pipe for service point 1 but im not tracking for doing this setup in a PTP850S?
If you want inband management on one interface, then the mgmt interface will need it’s own VLAN. Also make sure you enable inband management on the local network config page.
I don’t actually have the ‘In-Band Managment Configuration’ option available to me. All I see is the IP Family Configuration and IP Configuration. Would you know why this might be?
The “In-Band Configuration” option under the Local Networking config area is only applicable to PTP850 radios. It’s not available or needed on PTP820 radios.
I have the PTP-850s model. I am having massive capacity issues and it won’t allow me to push anymore than 15mbps through the link and I’m trying to track down why.
