Hello
Im having this issue with a CPE disconnecting from AP
F=5775 11naht20. Reason: 48 (COMMUNICATION LOST)
AP is ePMP2000 with version 4.3.2
CPE is 5 GHz Force 190 Radio (FCC) with version 4.3.2
Any suggestion?
Thank you
Hello
Any suggestion?
Thank you
If you have pure legacy equipment, you should be using 3.5.6, not 4.3.2. Only use 4.3.2 if you have a mix of AC and N equipment.
Either stick to 3.5.6 or use 4.4
