The uGPS is no longer shipping as of December 2018. It has been replaced with cnPulse. Refer to the cnPulse knowledge base for more information.
The UGPS provides location data to connected synchronized devices and may be retrieved by the access point/backhaul/cluster management module web GUI or by SNMP. GPS status and location data readout is currently available on PMP 100/320/400/430, and PTP 100/200/230, series radios.
Retrieving GPS Status and Location Data via Radio Web Management GUI
PMP 100/400/430 and PTP 100/200/230 Series
Step |
Action |
1 |
With the UGPS powered and connected to the radio, navigate to Home > GPS Status. |
2 |
GPS Location Data is displayed in section GPS Status. PMP 430 Example
Retrieving GPS status and location data via SNMP
To retrieve GPS Status and Location Data via SNMP (Simple Network Management Protocol) from synchronized devices operators may use the following procedures.
Step |
Action |
1 |
With the UGPS powered and connected to the radio, on the radio web management GUI navigate to Configuration > SNMP. |
2 |
Verify that the Community String and Accessing Subnet values are set as desired. |
3 |
Perform a “snmpget” command for the OID desired.
