Unable to connect to serial port on cnReach
In response to:
I did follow instruction above but it does not work on our radio. What is the Putty version. You guys are using?
The PuTTY version is unlikely to make any difference.
Do you see any output at all on the serial port when the cnReach boots? If not, are you sure you have configured PuTTY with the correct COM port?
