What is the default procedure for the CMM5 controller?
Does this knowledge-base post answer your question?
I do not have the password to login to the GUI
The only other post I found is here:
If no-one else replies, you should probably raise a support ticket.
Hi @paulmack,
although there is no way to recover a lost password on the CMM5 Controller, we can send you a replacement SD card loaded with the factory default configuration, along with installation instructions. Once installed, this will reset your Controller password to the default value, and you will be able to log in and re-enter your configuration. Can you please open a support ticket as Simon suggested?
Best regards,
Dave.
Thanks ticket opened.
