Marking QoS based on traffic
User can classily traffic base on source LAN IPs.  After classification  of traffic , user can assign priority and rate limit  on  classified traffic.
Step to configure.
  1. Configure static IP LAN PC or get fixed LAN PC IP using DHCP Static Allotment option.  (  Example IP: 192.168.11.143)
  2. Enable QOS.
  3. Add rule name for QOS identification.
  4. Add the classify  traffic rule based on source LAN IP( LAN Desktop  IP: 192.168.11.143).
  5. Assign Priority to classified traffic [VO(Highest) ->> CL(High)->> BE(Default)->> BK-(Low)]
  6. Configure rate limit as per usage.(This bandwidth is shared  with other low priority queues/traffic  if there is no or less traffic than assigned rate limit).
Niraj.
