PMP450/PMP450i and CMM4 Power supply comparative chart
Hi guys, I need your help to find the spec sheet for power supply N000000L034A. I need to do a comparative chart for a Telco that need to homologate the diferents models. I am attaching a file with the job I am doing, but I can not find anything about above power supply model. Could someone help me? Or share some comparative chart that could have. I will appreciate any help!!! My best to all.
Hi Juliochavarriac,
Here is the details about the power supply N000000L034A.
DESCRIPTION: POWER SUPPLY, 30W, 56V - Gbps support. For more details, please refer the below links.
http://community.cambiumnetworks.com/t5/PMP-450/Power-supplies/td-p/47637
http://community.cambiumnetworks.com/t5/PMP-FAQ/Powering-a-legacy-56-VDC-radio-using-N000000L034A/td-p/56548
https://www.winncom.com/en/products/N000000L034A
http://www.balticnetworks.com/cambium-gigabit-poe-power-supply-for-pmp450i-and-ptp450i-56vdc-30w.html
I hope the above would be helpful for you.
Regards,
Vijay Gnanamurthy
@Support_Vijay1 wrote:
Hi Juliochavarriac,
Regards,
Vijay Gnanamurthy
Hi Juliochavarriac,
Regards,
Vijay Gnanamurthy
Dear Vijay,
These links don't have the technical specifications like the others power supply.  Just I really need a comparative equal to the N000000L001A like is attached.
Or that someone help me to fill the excel sheet that I send previously in this post.
Thank you very much!
Regards,
Julio Chavarría
I forgot this file maybe... ;-)
