Introduction
This document highlights new features and significant updates in cnMaestro 2.2.1 On-Premises.
Important |
cnMaestro On-Premises 2.2.1 is a Package release rather than a full OVA image. It must be applied on top of an existing 2.2.0 On-Premises installation. Please follow the steps detailed in section 6.2 of the cnMaestro On-Premises 2.2.0 Quick Start Guide (“Updating cnMaestro Software”) to perform a package update on an existing OVA. |
Important: Web Browser |
You may need to restart your browser (or clear the browser cache with a hard reload) after the update. |
Important: Database Indexing Banner |
Once the backup data is successfully imported, the following banner will be displayed in the top of cnMaestro On-Premises UI, and it will remain there until the indexing is completed.
ePSK Support for cnPilot Enterprise
WPA2 Multiple PSK (ePSK) support for cnPilot Enterprise APs allows Client authentication based on a list of valid PSK passphrases, which are optionally tied to a specific Client MAC address. The VLAN parameter can also be specified.
The ePSK feature is available in the Enterprise WLAN configuration of the UI, or through the RESTful API.
Hide Default Configuration Templates
Optionally hide default configuration templates by choosing “Custom” option in Template Type drop down.
Hide SMs in Network Map
By default, Subscriber Modules are hidden, to avoid cluttering the Sector Visualization view.
SNR Graphs for PMP SMs
The SNR (Vertical and Horizontal) performance graphs are added for PMP SMs.
MSP Access to Operator and Monitor Users ![]()
Operator and Monitor Users in the Base Infrastructure can now access MSP (Managed Service Provider) accounts with the authorization of their respective roles.
Fast SMS Gateway Support for Guest Access ![]()
Support for Fast SMS Gateway is added for Guest Access.
Debug Option for cnMatrix Switches
User interface to execute CLI commands on cnMatrix switches as part of Debug option. This feature is supported on cnMatrix switches running with software version 2.0.5 or higher.
CPU Usage Graph for cnPilot Home (R-Series)
Added CPU Usage graph for cnPilot Home APs.
CPU Usage Graph for PMP Devices
Added CPU Usage graph for PMP devices.
API Updates (On-Premises) ![]()
New APIs
Path |
Details |
WLAN ePSK API (Section 21) |
/api/v1/wifi-enterprise/wlans/{WLAN Name}/epsk |
List of ePSK entries |
/api/v1/wifi-enterprise/wlans/{WLAN Name}/epsk/generate |
Generate ePSK entries |
/api/v1/wifi-enterprise/wlans/{WLAN Name}/epsk/delete |
Delete ePSK entries |
/api/v1/wifi-enterprise/wlans/{WLAN Name}/epsk?expired=true |
Delete expired ePSK entries |
Supported Cambium Products
cnMaestro supports the following Cambium Networks products. The software versions are the minimum required to use cnMaestro (not the recommended versions).
Family |
Model |
Version |
cnPilot |
cnPilot R200, R200P |
4.2.3-R4 |
cnPilot R201, R201P |
4.2.3-R4 |
cnPilot R190V, R190W |
4.3.2-R4 |
cnPilot R195W |
4.5.2-R5 |
cnPilot E400/E500 |
2.5.2-r3 |
cnPilot E410/E430w/E600 |
3.5.2-R4 |
cnPilot E501S |
3.2.1-r6 |
cnPilot E502S |
3.2.1-r6 |
cnPilot E700 |
3.8 |
ePMP 1000 Hotspot |
ePMP 1000 Hotspot |
2.5.2-r3 |
ePMP |
ePMP 1000, Force 180/200 |
2.6.2 |
ePMP 2000 |
3.0.1 |
ePMP Elevate |
3.0.1 |
ePMP Force 190 |
3.5 |
ePMP Force 300 |
4.1.1 |
ePMP Force 300-25 |
4.1.1 |
ePMP Force 300-16 |
4.3.0.1 |
ePMP PTP 550 |
4.1.1 |
ePMP 3000 |
4.3.0.1 |
PMP |
PMP 450i, PMP 450, PMP 450m, PMP 430 SM |
15.0.1 |
PTP 450, and PTP 450i |
15.0.1 |
PTP |
PTP 650 |
01-47 |
PTP 670 (650 Emulation) |
01-47 |
PTP 670, PTP 700 |
02-67 |
cnReach (Beta) |
N500 |
5.2.17e |
cnMatrix |
cnMatrix |
2.0.4-r1 |
Supported Browsers
cnMaestro supports the following browsers:
Platform |
Browser |
Version |
Windows |
Internet Explorer |
11 and above |
Firefox |
45 and above |
Chrome |
49 and above |
Microsoft Edge |
44.17763.1.0 and above |
MacOS |
Safari |
9 and above |
Linux |
Firefox |
45 and above |
Chrome |
49 and above |
Significant Fixes
The following issues have been fixed:
Id |
Details |
CNSSNG-10189 |
RSSI chart difficult to read. |
CNSSNG-11734 |
PTP 650 missing graphs with SW version 50650-01-47. |
CNSSNG-11677 |
Unable to move to Manage Users page by clicking on Users tab from tree and Add Users from Home page. |
CNSSNG-9066 |
Mass job deletion can leave devices stuck in a locked state. |
CNSSNG-11644 |
PTP650/670: Performance graphs are empty with build 1-47. |
CNSSNG-11852 |
cnPilot R series devices getting upgraded from below 4.3 version to 4.5-R7 needs to be upgraded first to 4.4.2-R2 and then to 4.5-R7. |
Known Issues
The following issues exist:
Id |
Issue |
Details |
AURA-388 |
WiFi Guest Access does not work with Microsoft Edge Browser |
Guest Access on cnMaestro does not work with Edge browser on cnPilot 1.4.0-r12 with 3.2.1-6 and 1.5.0-r4 with 3.3 beta builds. Workaround: Users need to use supported browsers like Chrome, Firefox, or Internet Explorer (IE) 11. |
AURA-470 |
Failure to load success page after quick pay authentication |
AURA-474 |
Error contacting server when clicking on Orange Money button |
CNSSNG-4083 |
DHCP errors after cnMaestro Reboot |
When cnMaestro On-Premises is rebooted, after Data Import, sometimes DHCP and Disk Errors are encountered. Workaround: Explicitly run the dhclient command from the Command Line (accessed through the CLI) after reboot to assign the IP address. |
CNSSNG-4906 |
Captive Portal Auto Login fails with latest Android devices |
Workaround: Whitelist the URL for Google (*.google.com). |
CNSSNG-5365 |
RADIUS Proxy drops packets after retry exhausted |
After RADIUS Proxy Retries are exhausted in cnMaestro On-Premises, all subsequent RADIUS packets are dropped. Workaround: Reboot cnMaestro. |
CNSSNG-7626 |
Access token is expired after data migration |
Workaround: User has to generate a new token after the migration. |
CNSSNG-7372 |
Auto sync always times out if the device IP changes during auto sync |
CNSSNG-8304 |
ePMP: “No GPS Sync” or |
ePMP devices are not sending the GPS Sync status events to cnMaestro when GPS Sync is down or there is NO GPS Sync. Also for PMP GPS SYNC events, details shows sync source instead of indicating whether the GPS SYNC source is up or Down. |
CNSSNG-10145 |
Certificate export is not part of Data Backup and restore |
Certificates must be exported manually. |
CNSSNG-10187 |
While Migration is happening moving or deleting a device from the Managed account will mark all the events and alarms as undefined once migration is completed |
CNSSNG-10223 |
MSP images not imported on server when exported in 1.6.3 and imported in 2.1.0 |
Workaround: Customers need to apply 1.6.3-r39 build and then import the data to 2.1.0 |
CNREACH-139 |
Radio Software Update is not happening for EP based devices. |
Where to Get Help
There are a number of places to get help with cnMaestro.
Cambium Community: The cnMaestro Forum provides the best place to ask questions and get up-to-date information.
On-Premises Quick Start Guide: This guide walks you through the initial management process and allows you to get onboarded quickly. It is embedded into the cnMaestro image and can be accessed on the Home Page of the UI. It can also be downloaded in PDF format from the Cambium Support website.
Cambium Support: The Cambium Support team is available 24x7 to answer questions and resolve issues.
