Tx Power Configuration
Tx Power is one of most important parametrs for Radio Links planning.
Tx Power is very complex parameter with plenty of dependencies and restrictions.
All ePMP 1000 devices have 3 main operating modes:
  • TDD mode — Supports Time Division Duplex with GPS sync, best suits for PMP(point-to-multipoint) networks. TDD PTP is almost the same TDD with only difference — only one SM can be registered on AP.
  • ePTP Master/Slave mode - Focused to provide minimum possible latency on PTP(point-to-point) links. Does not support GPS sync.
  • Standard Wi-Fi mode — Totally based on 802.11a/b/g/n standard. Widely used for migration from Standard 802.11 systems to ePMP systems.
Every ePMP device can be used in Access Point(AP) or Subscriber Module(SM) role.
Important to know difference between Tx Power shown on UI for AP and SM.
In general ePMP devices distinguish two types of traffic — data traffic and management traffic.
ePMP always try to send Data traffic on the highest possible MCS, Management traffic always uses MCS1 or MCS0(Configurable option on UI).
Becauses of this Tx Power for Data packets and for Management packets will be different.
Each AP may have several SMs registered on it.
Therefore it was decided that AP will indicate Tx Power of Management packets on UI and SMs will indicate Tx Power of all packets(Data + Management). AP communicates with all registered on it SMs and Data packets TX Power will be different for each of them. Only Data Tx Power transmitted with same value for all registered SMs.
Over all there are three things which limits Tx Power:
  • Regulatory;
  • ATPC (Automatic Transmission Power Control) — works only in TDD and TDD PTP mode;
  • Dynamic Tx Power.
Regulatory — all wireless devices in bands 2.4 GHz and 5 GHz should follow rules established by the State. Regulatory limitation depends on Country Code, Frequency Band, Operating Mode(PTP/PMP). APs and SMs follow regulatory policies.
Automatic Transmit Power Control (ATPC) is a feature used in Wireless systems that adjusts transmitter output power based on the varying signal level at the receiver. ATPC allows the transmitter to operate at lower than maximum power for most of the time, transmit power will be increased as needed until the maximum is reached in case of changed environment. An ATPC provides several advantages over a fixed transmit power system, including less transmitter power consumption, longer amplifier component life, and reduced interference for other Wireless systems. Especially important in case of Frequency Reuse with sync network. SMs from one sector do not produce heavy interference for AP in adjacent sector.
ATPC options are available for configuration on AP in Power Control section on UI.
Subscriber Module Target Receive Level is the desired Uplink RSSI level. Tx Power on SM will be increased till Subscriber Module Target Receive Level is not reached. In case of redundant Tx Power of SM in will be reduced.
On SM side there is option Max Tx Power Auto or Manual. In auto mode ATPC completely controls Tx Power.
Please be careful, in case of Manual mode, ATPC controls Tx Power too, but entered value will be the upper line, above which Tx Power can not be increased.
Dynamic TX Power - the restriction caused by the transceiver system quality indicators. Transmitter power limit associated with an increased error vector magnitude (EVM - Error Vector Magnitude) on higher MCSs with more complex modulation types. Limitation has frequency dependence, and also depends on the device type. For each ePMP device platform there are separate tables with Dynamic Tx Power limitation.
Tx Power Limits for PTP 550
5.735-5.98 GHz Band
5.54 – 5.71 GHz Band
5.17 - 5.29 GHz Band
MCS
Payloads
20 MHz
40 MHz
80 MHz
20 MHz
40 MHz
80 MHz
20 MHz
40 MHz
80 MHz
MCS1
Single
25
24
23
25
24
23
26
25
25
MCS2
Single
25
23
23
25
24
23
26
25
25
MCS3
Single
25
23
23
25
23
23
26
25
25
MCS4
Single
25
23
23
25
23
23
26
25
25
MCS5
Single
23
23
23
23
23
23
25
25
25
MCS6
Single
22
22
22
22
22
22
23
23
23
MCS7
Single
21
21
21
21
21
21
22
22
22
MCS8
Single
20
20
20
20
20
20
22
22
22
MCS9
Single
20
20
20
20
20
20
21
21
21
MCS1
Dual
19
19
19
19
19
19
20
20
20
MCS2
Dual
25
23
23
25
24
23
26
25
25
MCS3
Dual
25
23
23
25
23
23
26
25
25
MCS4
Dual
25
23
23
25
23
23
26
25
25
MCS5
Dual
23
23
23
23
23
23
25
25
25
MCS6
Dual
22
22
22
22
22
22
23
23
23
MCS7
Dual
21
21
21
21
21
21
22
22
22
MCS8
Dual
20
20
20
20
20
20
22
22
22
MCS9
Dual
20
20
20
20
20
20
21
21
21
ePMP 3000 5GHz
Bandwidth Freq-Limits SS SS DS DS
0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9
ROW
20MHz 4910-5465 33 33 33 33 33 32 31 30 29 29 33 33 33 33 33 32 31 30 29 29
5470-5720 33 33 33 33 33 33 32 31 30 30 33 33 33 33 33 33 32 31 30 30
5725-5980 33 33 33 33 32 31 30 29 29 28 33 33 33 33 32 31 30 29 29 28
40MHz 4910-5465 33 33 33 33 32 32 31 30 30 29 33 33 33 33 32 32 31 30 30 29
5470-5720 33 33 33 33 33 32 32 31 30 30 33 33 33 33 33 32 32 31 30 30
5725-5980 33 33 33 32 32 31 30 29 29 28 33 33 33 32 32 31 30 29 29 28
80MHz 4910-5465 33 33 33 33 32 32 31 30 30 29 33 33 33 33 32 32 31 30 30 29
5470-5720 33 33 33 33 33 32 31 31 30 30 33 33 33 33 33 32 31 31 30 30
FCC
20MHz 5150-5465 33 33 33 33 33 33 32 31 31 30 33 33 33 33 33 33 32 31 31 30
5725-5980 33 33 33 33 33 32 31 30 30 29 33 33 33 33 33 32 31 30 30 29
40MHz 5150-5465 33 33 33 33 33 33 32 31 31 30 33 33 33 33 33 33 32 31 31 30
5725-5980 33 33 33 33 32 31 31 30 30 29 33 33 33 33 32 31 31 30 30 29
80MHz 5150-5465 33 33 33 33 33 33 32 31 31 30 33 33 33 33 33 33 32 31 31 30
Device Description Device 2G/5G Band Freq-Limits SS SS DS DS
F300-25 FCC F300 5GHz 20MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
5735-5980 29 29 29 28 28 27 27 26 25 24 29 29 29 28 28 27 27 26 25 24
F300-25 FCC F300 5GHz 40MHz 4910-5730 29 29 29 29 29 28 27 27 26 26 29 29 29 29 29 28 27 27 26 26
5735-5980 29 29 29 28 28 27 26 26 25 24 29 29 29 28 28 27 26 26 25 24
F300-25 FCC F300 5GHz 80MHz 4910-5730 29 29 29 29 29 28 27 27 26 26 29 29 29 29 29 28 27 27 26 26
5735-5980 29 29 29 29 28 27 26 26 25 24 29 29 29 29 28 27 26 26 25 24
F300-25 ROW F300 5GHz 20MHz 4910-5730 29 29 29 29 29 28 27 27 26 25 29 29 29 29 29 28 27 27 26 25
5735-5980 29 29 29 29 28 27 26 25 25 24 29 29 29 29 28 27 26 25 25 24
F300-25 ROW F300 5GHz 40MHz 4910-5730 29 29 29 29 29 28 27 27 26 25 29 29 29 29 29 28 27 27 26 25
F300-25 ROW F300 5GHz 80MHz 4910-5730 29 29 29 29 29 28 27 27 26 25 29 29 29 29 29 28 27 27 26 25
F300-16 FCC F220 5GHz 20MHz 5150-5465 30 30 29 29 29 29 28 27 27 26 30 30 29 29 29 29 28 27 27 26
5470-5730 30 30 29 29 29 28 27 27 26 25 30 30 29 29 29 28 27 27 26 25
5735-5980 30 30 29 29 28 27 27 26 26 26 30 30 29 29 28 27 27 26 26 26
F300-16 FCC F220 5GHz 40MHz 5150-5465 30 30 29 29 29 29 28 27 26 26 30 30 29 29 29 29 28 27 26 26
5735-5980 30 30 29 29 28 27 26 26 25 25 30 30 29 29 28 27 26 26 25 25
F300-16 FCC F220 5GHz 80MHz 5150-5465 30 30 29 29 29 29 28 27 26 26 30 30 29 29 29 29 28 27 26 26
5735-5980 29 29 29 29 28 27 26 26 25 25 29 29 29 29 28 27 26 26 25 25
F300-16 ROW F220 5GHz 20MHz 4910-5465 30 30 29 29 29 29 28 27 27 26 30 30 29 29 29 29 28 27 27 26
5470-5730 30 30 29 29 29 29 28 27 27 26 30 30 29 29 29 29 28 27 27 26
5735-5980 30 30 29 29 29 29 28 27 27 26 30 30 29 29 29 29 28 27 27 26
F300-16 ROW F220 5GHz 40MHz 4910-5465 30 30 29 29 29 29 28 27 27 26 30 30 29 29 29 29 28 27 27 26
5735-5980 30 30 29 29 28 27 26 26 25 24 30 30 29 29 28 27 26 26 25 24
F300-16 ROW F220 5GHz 80MHz 4910-5465 30 30 29 29 29 29 28 27 27 26 30 30 29 29 29 29 28 27 27 26
F300-13 ROW F300 5GHz 20MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-13 ROW F300 5GHz 40MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-13 ROW F300 5GHz 80MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19 ROW F300 5GHz 20MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19 ROW F300 5GHz 40MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19 ROW F300 5GHz 80MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19R ROW F300 5GHz 20MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19R ROW F300 5GHz 40MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19R ROW F300 5GHz 80MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
MAXrP IP67 ROW F300 5GHz 20MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
MAXrP IP67 ROW F300 5GHz 40MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
MAXrP IP67 ROW F300 5GHz 80MHz 4910-5980 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-13 FCC F300 5GHz 20MHz 5150-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
5735-5980 29 29 29 29 29 28 27 25 24 24 29 29 29 29 29 28 27 25 24 24
F300-13 FCC F300 5GHz 40MHz 5150-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-13 FCC F300 5GHz 80MHz 5150-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19 FCC F300 5GHz 20MHz 4910-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19 FCC F300 5GHz 40MHz 4910-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19 FCC F300 5GHz 80MHz 4910-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19R FCC F300 5GHz 20MHz 4910-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19R FCC F300 5GHz 40MHz 4910-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-19R FCC F300 5GHz 80MHz 4910-5730 29 29 29 29 29 28 27 26 25 24 29 29 29 29 29 28 27 26 25 24
F300-25L F300 5GHz 20MHz 4910-5980 27 27 27 26 25 24 23 22 21 20 27 27 27 26 25 24 23 22 21 20
F300-25L F300 5GHz 40MHz 4910-5980 27 27 27 26 25 24 23 22 21 20 27 27 27 26 25 24 23 22 21 20
F300-25L F300 5GHz 80MHz 4910-5980 27 27 27 26 25 24 23 22 21 20 27 27 27 26 25 24 23 22 21 20
F300-22L F300 5GHz 20MHz 4910-5980 27 27 27 26 25 24 23 22 21 20 27 27 27 26 25 24 23 22 21 20
F300-22L F300 5GHz 40MHz 4910-5980 27 27 27 26 25 24 23 22 21 20 27 27 27 26 25 24 23 22 21 20
F300-22L F300 5GHz 80MHz 4910-5980 27 27 27 26 25 24 23 22 21 20 27 27 27 26 25 24 23 22 21 20
F300-13LC F300 5GHz 20MHz 4910-5980 28 28 28 28 27 26 25 24 23 22 28 28 28 28 27 26 25 24 23 22
F300-13LC F300 5GHz 40MHz 4910-5980 28 28 28 28 27 26 25 24 23 22 28 28 28 28 27 26 25 24 23 22
F300-13LC F300 5GHz 80MHz 4910-5980 28 28 28 28 27 26 25 24 23 22 28 28 28 28 27 26 25 24 23 22
F300-13L F300 5GHz 20MHz 4910-5980 28 28 28 28 27 26 25 24 23 22 28 28 28 28 27 26 25 24 23 22
F300-13L F300 5GHz 40MHz 4910-5980 28 28 28 28 27 26 25 24 23 22 28 28 28 28 27 26 25 24 23 22
F300-13L F300 5GHz 80MHz 4910-5980 28 28 28 28 27 26 25 24 23 22 28 28 28 28 27 26 25 24 23 22
Tx Power Limits for Force 200L
Frequency range MCS0 DS MCS1 DS MCS2 DS MCS3 DS MCS4 DS MCS5 DS MCS6 DS MCS7 DS
4920-5745 30 30 30 27 24 23 22 21
5750-5995 30 30 30 28 24 22 21 20
6000-6240 27 27 27 27 26 24 23 22
The same limits will be for SS and DS on 5,10,20,40 Mhz channels.
Is a table available for 3000 / 3000L products?
@jessearcher
ePMP 3000 5GHz
ROW
FCC
Thanks, does the same table apply for Force 300 products?
@jessearcher , it is slightly different.
Tx Power Limits for Force 200L added to the top post.
Is it possible to update this post for the various ePMP 4000 series products?
Also want to check if this table applies to 3000L?
E3KL-FCC E3KL 5GHz 20MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
E3KL-FCC E3KL 5GHz 40MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
E3KL-FCC E3KL 5GHz 80MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
E3KL-ROW E3KL 5GHz 20MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
5735-6420 29 29 29 28 28 27 27 26 25 24 29 29 29 28 28 27 27 26 25 24
E3KL-ROW E3KL 5GHz 40MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
E3KL-ROW E3KL 5GHz 80MHz 4910-5730 29 29 29 29 29 28 28 27 26 26 29 29 29 29 29 28 28 27 26 26
Hi @jessearcher,
it is slightly different. Check my post above!
Device Description Device 2G/5G Band Freq-Limits SS G H I J K L M N O P Q R SS DS U V W X Y Z AA AB AC AD AE AF DS
0 1 2 3 4 5 6 7 8 9 10 11 12 13 0 1 2 3 4 5 6 7 8 9 10 11 12 13
E4K ROW E4K 5GHz 20MHz 4910-6180 33 33 33 32 31 30 29 29 28 28 28 27 33 33 33 32 31 30 29 29 28 28 28 27
40MHz 4910-6180 32 32 32 32 31 30 29 28 27 27 27 26 32 32 32 32 31 30 29 28 27 27 27 26
80MHz 4910-6180 32 32 32 32 31 30 29 28 27 27 27 26 32 32 32 32 31 30 29 28 27 27 27 26
E4K FCC E4K 5GHz 20MHz 4910-6180 33 33 33 32 31 30 29 29 28 28 28 27 33 33 33 32 31 30 29 29 28 28 28 27
E4KC ROW E4K 5GHz 20MHz 4910-6180 33 33 33 32 31 30 29 29 28 28 28 27 33 33 33 32 31 30 29 29 28 28 28 27
E4KC FCC E4K 5GHz 20MHz 4910-6180 33 33 33 32 31 30 29 29 28 28 28 27 33 33 33 32 31 30 29 29 28 28 28 27
ePMP4500L ROW E4KL 5GHz 20MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5160-5730 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5735-5970 28 28 28 26 26 26 25 25 24 24 22 22 28 28 28 26 26 26 25 25 24 24 22 22
5975-6050 23 23 23 21 21 21 21 21 21 21 19 19 23 23 23 21 21 21 21 21 21 21 19 19
6055-6095 23 23 23 21 21 21 21 21 18 18 14 14 23 23 23 21 21 21 21 21 18 18 14 14
6100-6180 23 23 23 19 19 19 19 19 11 11 11 11 23 23 23 19 19 19 19 19 11 11 11 11
ePMP4500L ROW E4KL 5GHz 40MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
ePMP4500L ROW E4KL 5GHz 80MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5735-5940 28 28 28 26 26 26 25 25 24 24 22 22 28 28 28 26 26 26 25 25 24 24 22 22
5945-6020 23 23 23 21 21 21 21 21 21 21 19 19 23 23 23 21 21 21 21 21 21 21 19 19
6025-6095 23 23 23 21 21 21 21 21 18 18 14 14 23 23 23 21 21 21 21 21 18 18 14 14
ePMP4500L FCC E4KL 5GHz 20MHz 4910-5155 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
5160-5330 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5335-5710 28 28 28 28 28 27 25 25 24 24 22 22 28 28 28 28 28 27 25 25 24 24 22 22
5715-5970 27 27 27 25 25 25 25 25 24 24 22 22 27 27 27 25 25 25 25 25 24 24 22 22
ePMP4500L FCC E4KL 5GHz 40MHz 4910-5155 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
ePMP4500L FCC E4KL 5GHz 80MHz 4910-5185 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
5190-5300 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5305-5680 28 28 28 28 28 27 25 25 24 24 22 22 28 28 28 28 28 27 25 25 24 24 22 22
5685-5940 27 27 27 25 25 25 25 25 24 24 22 22 27 27 27 25 25 25 25 25 24 24 22 22
F400 GPS ROW F400/425 5GHz 20MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400 GPS ROW F400/425 5GHz 40MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400 GPS ROW F400/425 5GHz 80MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400 GPS FCC F400/425 5GHz 20MHz 4910-5155 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
F400 GPS FCC F400/425 5GHz 40MHz 4910-5155 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
F400 GPS FCC F400/425 5GHz 80MHz 4910-5185 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
F425 ROW F400/425 5GHz 20MHz 4910-5890 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5895-5970 28 28 28 28 28 27 26 24 23 22 20 20 28 28 28 28 28 27 26 24 23 22 20 20
5975-6050 24 24 24 23 23 23 21 21 21 21 19 19 24 24 24 23 23 23 21 21 21 21 19 19
6055-6095 23 23 23 21 21 21 21 21 20 18 16 16 23 23 23 21 21 21 21 21 20 18 16 16
6100-6180 23 23 23 19 19 19 19 19 18 15 12 12 23 23 23 19 19 19 19 19 18 15 12 12
F425 ROW F400/425 5GHz 40MHz 4910-5890 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F425 ROW F400/425 5GHz 80MHz 4910-5860 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
5865-5940 28 28 28 28 28 27 26 24 23 22 20 20 28 28 28 28 28 27 26 24 23 22 20 20
5945-6020 24 24 24 23 23 23 21 21 21 21 19 19 24 24 24 23 23 23 21 21 21 21 19 19
6025-6095 23 23 23 21 21 21 21 21 20 18 16 16 23 23 23 21 21 21 21 21 20 18 16 16
F425 FCC F400/425 5GHz 20MHz 4910-5890 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F425 FCC F400/425 5GHz 40MHz 4910-5890 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F425 FCC F400/425 5GHz 80MHz 4910-5860 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400C ROW F400/425 5GHz 20MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400C ROW F400/425 5GHz 40MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400C ROW F400/425 5GHz 80MHz 4910-5155 28 28 28 28 28 27 26 26 25 24 22 22 28 28 28 28 28 27 26 26 25 24 22 22
F400C FCC F400/425 5GHz 20MHz 4910-5155 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
F400C FCC F400/425 5GHz 40MHz 4910-5155 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
F400C FCC F400/425 5GHz 80MHz 4910-5185 28 28 28 26 26 24 23 23 22 22 21 21 28 28 28 26 26 24 23 23 22 22 21 21
F425L ROW F400/425 5GHz 20MHz 4910-5155 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
5160-5700 28 28 28 28 27 27 26 26 25 24 22 22 28 28 28 28 27 27 26 26 25 24 22 22
5705-5980 28 28 28 28 27 27 26 26 25 24 22 21 28 28 28 28 27 27 26 26 25 24 22 21
F425L ROW F400/425 5GHz 40MHz 4910-5155 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
F425L ROW F400/425 5GHz 80MHz 4910-5185 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
5990-5670 28 28 28 28 27 27 26 26 25 24 22 22 28 28 28 28 27 27 26 26 25 24 22 22
5675-5980 28 28 28 28 27 27 26 26 25 24 22 21 28 28 28 28 27 27 26 26 25 24 22 21
F425UL ROW F400/425 5GHz 20MHz 4910-5155 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
F425UL ROW F400/425 5GHz 40MHz 4910-5155 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
F425UL ROW F400/425 5GHz 80MHz 4910-5185 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
F425L FCC F400/425 5GHz 20MHz 4910-5155 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
F425L FCC F400/425 5GHz 40MHz 4910-5155 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
F425L FCC F400/425 5GHz 80MHz 4910-5185 27 27 26 26 25 24 24 23 22 22 21 20 27 27 26 26 25 24 24 23 22 22 21 20
E6K ROW FCC E6K 6GHz 20MHz 5735-7125 31 31 31 30 29 29 28 27 27 26 26 25 23 23 31 31 31 30 29 29 28 27 27 26 26 25 23 23
40MHz 5735-7125 31 31 31 30 29 28 28 27 26 26 25 24 22 22 31 31 31 30 29 28 28 27 26 26 25 24 22 22
80MHz 5735-7125 31 31 31 30 29 28 28 27 26 26 25 24 22 22 31 31 31 30 29 28 28 27 26 26 25 24 22 22
160MHz 5735-7125 31 31 31 30 29 28 28 27 26 26 25 24 21 21 31 31 31 30 29 28 28 27 26 26 25 24 21 21
F600L ROW FCC F600 6GHz 20MHz 5735-5945 28 28 28 26 26 25 24 24 23 23 22 21 19 18 28 28 28 26 26 25 24 24 23 23 22 21 19 18
40MHz 5735-5945 27 27 27 26 26 25 24 24 23 23 22 21 19 18 27 27 27 26 26 25 24 24 23 23 22 21 19 18
80MHz 5735-5975 27 27 27 26 26 25 24 24 23 23 22 21 19 18 27 27 27 26 26 25 24 24 23 23 22 21 19 18
160MHz
F600L ROW FCC F600 6GHz 20MHz 5950-7125 28 28 28 26 26 25 24 24 23 23 23 22 19 19 28 28 28 26 26 25 24 24 23 23 23 22 19 19
40MHz 5950-7125 27 27 27 26 26 25 24 24 23 23 22 21 19 19 27 27 27 26 26 25 24 24 23 23 22 21 19 19
80MHz 5980-7125 27 27 27 26 26 25 24 24 23 23 22 21 19 19 27 27 27 26 26 25 24 24 23 23 22 21 19 19
160MHz 5950-7125 27 27 27 26 26 25 24 24 23 23 22 21 18 18 27 27 27 26 26 25 24 24 23 23 22 21 18 18
F600C ROW FCC F600/625 6GHz 20MHz 5735-5945 28 28 28 26 26 25 24 24 23 23 22 21 19 18 28 28 28 26 26 25 24 24 23 23 22 21 19 18
160MHz
F600C ROW FCC F600/625 6GHz 20MHz 5950-7125 28 28 28 26 26 25 24 24 23 23 23 22 19 19 28 28 28 26 26 25 24 24 23 23 23 22 19 19
F616 ROW F600/625 6GHz 20MHz 5915-7125 30 30 29 29 28 26 25 24 23 22 21 20 30 30 29 29 28 26 25 24 23 22 21 20
40MHz 5915-7125 29 29 28 27 26 25 24 23 23 22 21 20 29 29 28 27 26 25 24 23 23 22 21 20
80MHz 5915-7125 29 29 28 27 26 25 24 23 23 22 21 20 29 29 28 27 26 25 24 23 23 22 21 20
160MHz 5915-7125 29 29 28 27 26 25 24 23 23 22 21 20 29 29 28 27 26 25 24 23 23 22 21 20
F625 ROW F600/625 6GHz 20MHz 5915-7125 30 30 29 29 28 26 25 24 23 22 21 20 30 30 29 29 28 26 25 24 23 22 21 20
F616 USB GPS FCC F600/625 6GHz 20MHz 5915-7125 30 30 29 29 28 26 25 24 23 22 21 20 30 30 29 29 28 26 25 24 23 22 21 20
F625 USB GPS FCC F600/625 6GHz 20MHz 5915-7125 30 30 29 29 28 26 25 24 23 22 21 20 30 30 29 29 28 26 25 24 23 22 21 20
